Worth Swaping 3400 heads onto 3100 block???
  • GPTuner
    • 54
    First of all, whats up guys, This is my first post on here so you can all just call me NEW-B for a while haha
    My main question is....well is there a difference in flow chart numbers between the 3400 and the 3100??? since the difference between the two motors 5 HP im wondering if it's even worth the trouble. Would I see any gains?? Or will it not do much of anything.
    Also i plau to swap the 3400 TB and upper intake onto the 3100, since i will have those off i was wondering if i would see anything more with the 3400 heads????
    Thanks in advance guys
    http://profile.myspace.com/index.cfm...endid=14262310
  • Manitcor
    • 573
    the difference is actually more like 20hp for the 99 and earlier 3100s and less for the 00 and better.
    For the work involved I would just swap the entire engine since a low mile 3400 can be had pretty cheaply.
    1995 Monte Carlo LS
    3400 SFI 60v6
      • 13531
      what year are we talking about? There is quite a difference in casting quality between years. The non roller castings are pretty bad. I haven't flowed the head yet but as soon as I am doing trying to flowmatch this last exhaust port I will throw the 95 3100 head on the bench and see how it looks. Aside from a single cylinder, I am guessing from the looks of it that the flow will be pretty difference between ports.
      • GPTuner
        • 54
        Its a 2000, 3100 and these parts are from a seized 3400 same year motor.
        I know they will bolt right up, ive fitted a new headgasket for the 3100 onto this 3400 and all the holes line up perfectly. but i havent pulled my heads off just yet, to do a comparison, and take measurements on the intake, valves, and exaust ports
        • Manitcor
          • 573
          wont matter for you then, IIRC the topend on an 00+ 3100 and an 00+ 3400 are identical.
          1995 Monte Carlo LS
          3400 SFI 60v6
          • GPTuner
            • 54
            Damn I was kinda hoping they would be somewhat larger....oh well, i guess i'll just gasket match everything insted, thanks guys
              • 13531
              Yup, identical. If you pull the heads, check the casting number on them for me.
              • GPTuner
                • 54
                no problem
                • Syn
                  The Master Piece
                  • Oct 2005
                  • 599
                  got the 3400 intakes?
                  • GPTuner
                    • 54
                    I have the whole 3400 motor, the botom end seized, so im trying to make good use of the whole top end lower and upper intake manifold, heads, TB, anything i can swap over, that will make a difference
                    I havent gotten around to any of this yet, im waiting for the weather to be a bit less crappy so the motor sits in a garage full of crap till i can get around to it, while i work on my GTP
