Injector Upgrade ?
  • zofo61
    Banned
    • Oct 2005
    • 436
    Injector Upgrade ?
    Will the L67 36# injectors work with the 3500 UIM and do I need to change the connectors if they do?
    Thanks in advance
    Chris
  • onefastV6
    • Sep 2005
    • 880
    Chris -
    Check into the 4.2L Trail Blazer injectors, I am pretty sure that they are a direct replacement.
    2000 Grand Am GT
    2011 Chevy Impala
    • zofo61
      Banned
      • Oct 2005
      • 436
      Thank-you .....kind Sir !
      Do you know what Poundage they are?...I found a set on eBay but I want to make sure....The part # 2225A and 25358575 are listed for the 4.2L inline 6
      • sprucegagt
        Old School KI
        • May 2005
        • 703
        The TB injectors are 28 lb while the L67 injectors are really 33 lb. They just flow 36 lbs at 55 PSI. You will need the connectors for the L67 injectors.
        Your local OBDII moderator
        2000 Grand Am GT w/ WOT parts
        • onefastV6
          • Sep 2005
          • 880
          Looks like Spruce beat me to it.
          Are you still planning on running the RSM supercharger? I now have in my possession a RSM charger as well, but I am not sure of the future of my car since I just got a decent job offer.
          2000 Grand Am GT
          2011 Chevy Impala
          • zofo61
            Banned
            • Oct 2005
            • 436
            Yes I am putting back in once I get a supplier for the pulley bearring...also I have a few people working on a better shaft design.....like the one the Stattama Kit used for the 3.8 ..........also another guy is lloking into a braket design to put the charger on the pulley side using a pulley driven from the backside of the belt due to the fact that my charger is a clockwise rotator. Thanks for the info on the injectors....I think Im going with the L67's for more flow. Are you guys sure the L67s will fit considering the 3400 UIM covers the rail...I just want to be sure before I purchase them...I know that I have to change the connector for the L67s
            Thanks again
            • sprucegagt
              Old School KI
              • May 2005
              • 703
              They'll fit. I plan on using them myself in my car when my cam is ready.
              • zofo61
                Banned
                • Oct 2005
                • 436
                Does anyone know the GM part # for the L67 36# injectors ??
                • tejohnson
                  • 359
                  Off the top of my head, no, but:
                  Pretty good source for injectors ( since Ben doesn't sell them yet )
                  The 42.5# and 65# also work.
                  [Got your e-mail, just been a bit busy. Sold the 42.5# injectors a while back]
                  While you are at it, put that MAF back in!
                  Regards,
                  Todd E. Johnson
                  • zofo61
                    Banned
                    • Oct 2005
                    • 436
                    MAF going in with the injector upgrade and I found a guy in Daytona that knows the DHP PT very well so looks like things are finally getting lined up.............TE......that monster running yet?, Theres been wat too much time between your GroomLake pics on the project!!
                    • tejohnson
                      • 359
                      Well, it was running, and I went to Pontiac Nationals and spun a bearing:
                      Welcome to our website! Discover a range of top-quality products and services tailored to meet your needs. Browse through our pages to see how we can add value to your lifestyle. Join us in a seamless shopping experience that combines convenience, affordability, and speed. Explore more with us!
                      It was due to major detonation when the pump was sucked dry due to poor plumbing of the venturi line. Sucks to run outta fuel at 6700RPM.
                      Regards,
                      Todd E. Johnson
                      • AaronGTR
                        boost lover
                        • Jan 2004
                        • 708
                        The L67 injectors will definitely fit. They are actually a little shorter than your stock injectors so you won't have any clearance problems. I'm not sure about the difference in length between the L67's and the lucas 42lb injectors, but a lot of L67 guys use the 42's as an upgrade, and I'm using them too and they fit perfectly on my 3400.
                        '97 Grand Prix GT 3800 (sold)
                        Gotta love boost!
                          • 13531
                          I took a picture of the 4.2 trailblazer injector and a 3100/3400 multec 2 injector.
                          Are they rated for 28# at 43 psi or 55 psi?
