3900 Info
  • CNCguy
    Bisong eater :P
    • 1017
    #106
    Here you go Ben.
    The vavle timing checked at .006 lift is as follows:
    Intake Open: 25 BTDC
    Intake Close: 63 ABDC
    Intake Duration: 268
    Exhaust Open: 85 BBDC
    Exhaust Close: 1 ATDC
    Exhaust Duration: 266
    The vavle timing checked at .050 lift is as follows:
    Intake Open: 1 ATDC
    Intake Close: 30 ABDC
    Intake Duration: 209
    Exhaust Open: 59 BBDC
    Exhaust Close: 29 BTDC
    Exhaust Duration: 210
    The vavle timing checked at .260 lift is as follows:
    Intake Open: 71 ATDC
    Intake Close: 41 BBDC
    Intake Duration: 68
    Exhaust Open: 15 ABDC
    Exhaust Close: 80 TTDC
    Exhaust Duration: 65
    I did the .260 lift to find LSA. Usine this method, it comes up to 118. Still alot.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
      • 13534
      #107
      Dynomation won't accept -29 for the exhaust close. Oh well. 120.5 LSA.
      • CNCguy
        Bisong eater :P
        • 1017
        #108
        Can you bump all the numbers 10 degrees back and run it? 20 degrees? Just curious.
        '79 MGB - LZ9 - T5
          • 13534
          #109
          Hmm, probably but I just wanted to see how the cam looked. I need a lot more specs to run anything meaningful for the 3900 simulation.
          • CNCguy
            Bisong eater :P
            • 1017
            #110
            I am curious if this cam is even usable with fixed timing or if it can even be reground to use without VVT. If not, swapping this engine will have to wait til VVT control is worked out.
            '79 MGB - LZ9 - T5
              • 13534
              #111
              Ill need some flow numbers, min port area in sq in for intake and exhaust, exhaust manifold inlet diameter, exit diameter, intake manifold upper intake port area, gasket area, max lift, length from the valve seat to the plenum opening (runner length), and maybe some more info.
              A new cam will probably need to be ground if you want to make it worthwhile without the VVT. 120.5 LSA is quite a bit. I could try it on a 3500 and see what the power looks like
              • Joseph Upson
                #112
                I think I'm going to stick with the 3500 and get the 6spd transaxle instead. It would be crushing to swap the 3.9 only to discover a moderate improvement if that, due to the cam grind. Someone in GM is working against us regarding the cam journal size preventing interchange with non VVT cams.
                  • 13534
                  #113
                  Actually, at 10 degrees retarded on the timing, the cam specs will show good power from my 3500 simulation. I don't know that I would be turned off from the 3900 just yet.
                  • Joseph Upson
                    #114
                    I'm still weighing the cost vs. the benefits. My current 3500 cammed against the 3900 and .4 more litres with complication. Not quite the difference between the 305 and 350 small block chevy. I believe the 6spd with more torque handling capacity would be the better investment, but it has its baggage as well; dual mass flywheel, different splines on the input shaft and axles requiring a custom flywheel and clutch to insure holding capacity on high output applications, and combining 6spd specific axle parts with the Fieros axles. Perhaps I should focus on using what I have; 3500 with an apparently low mileage Getrag from a 92 Beretta and spend on stronger valve springs, the Zeitronics datalogger and the Moates Ostrich for the best tuning approach.
                    I would like the oil squirter on all 6 cylinders but I believe my 400 hp capacity oil cooler will still lend a good internal cooling effect.
                    • CNCguy
                      Bisong eater :P
                      • 1017
                      #115
                      As an alternative, I am going to check into how much the cam can be reground. Since it has more duration than the older stock cams, perhaps it can be more easily reground to reduce LSA. Other options would be to make cam bearing spacers or make some camshaft blanks. With bearing spacers or regrinds, longer pushrods will be required since the base circle will be smaller.
                      If it weren't for cost, the best solution would be new cam blanks that use the old style chain setup. Although it would eliminate the VVT feature, the engines could more easily be swapped into older vehicles, stock pushrods could be reused and more cam profiles could be offered.
                      I had hoped the stock cam could be used since I had a good idea on a mod that allowed the stock cam and gear to be used and had an adjustment for cam timing built into it. I also had a solution to limiting the VVT actuator travel for those wanting to toggle the cam timing.
                      Oh well..... I guess it's better to know the problems now before spending time and money making prototypes that can't be used. Time to do some more measuring and searching.
                      '79 MGB - LZ9 - T5
                      • Joseph Upson
                        #116
                        You said the base circle was larger than on the earlier cams so shouldn't that help provide room to bring the LSA back into something more reasonable for natural aspiration? I would like to stay the course having found a good price on an engine but I certainly don't want to risk it given that I'm probably in pretty good shape with the cammed 3500 being a bit closer to the 3900s hp output. The problem is the valve size and runner design in the 3900 may yield an astronomical overall output under boost relative to the 3500 at the same boost pressure. That's something I don't want to miss out on.
                        • CNCguy
                          Bisong eater :P
                          • 1017
                          #117
                          They did increase the base circle to 35.5mm diameter and IIRC, the old base circle was 32.0mm. The main tube size also increased so the wall thickness of the lobe only increased to about .5mm thicker (5.0mm vs. 4.5mm). Also, the 3900 has a slightly higher lift than the 3400 (.287 vs. .2727).
                          I wonder what Bens software shows for 20, 30, 40, etc degrees retard since the VVT can retard up to 54 degrees from the base numbers. Curious about the effects of such a large LSA and VVT.
                          '79 MGB - LZ9 - T5
                          • CNCguy
                            Bisong eater :P
                            • 1017
                            #118
                            I posted this in another thread but wanted to put a copy here to keep all the 3900 info together. I made a quickie template of the 3900 port and layed it on the 3400 LIM for a visual comparison. I put some red layout die on the manifold for contrast.
                            '79 MGB - LZ9 - T5
                            • MidnightriderZ24
                              • Jan 2005
                              • 699
                              #119
                              any news on the fuel injectors? what size are they, can bosch style be used?
                              [SIGPIC]
                              12.268@117... 11's to come!
                              • CNCguy
                                Bisong eater :P
                                • 1017
                                #120
                                I pulled the fuel rail off today. The 3400 fuel rail will not bolt to the 3900 LIM because the newer style use 3 mounting bolts. The injector (p/n 12592648 ) is 2.13 long compared to the 3.12 length of the 3400 injector (p/n 25322180) and uses a different connector. I have no idea what the flow rating is but would like to hear back if someone else knows.
                                '79 MGB - LZ9 - T5
