Originally posted by 2.8-350TBI
View Post
that certainly does answer my questions, thank you!
The above mentioned injectors should suit me well since the stock 3400 fuel rail runs @ 55psi. That means I shouldn't need to buy an adj. fpr unless the stock fpr is corrupted in which case I might as well upgrade.
26.2 lb/hr should definitely be enough for what I'm doing. If not, I will buy an adj. fpr and up the pressure to make them 28# just in case we need some more room to grow.
Glad to hear the 3400 rail will fit fine on the 3500 LIM, and that my stock sensors AND connectors should swap over without issue.
thanks again
max
