Originally posted by RedBird
View Post
My cam is reground so it should still perform well advanced, hopefully my bottom end response will be a lot stronger with 5 more inches of vacuum and headers. I have a Zeitronix WBO2 datalogger that has an auxillary output that I'm going to use to retard the cam. I tested it manually and it works because the engine rpm and sound changes when the module is energized.
You can use the shift light logic to control it also (on off) however it has a ~6360 rpm limit and I have my rev limit set around 6500.
I like the way it sounds muffled also, the silencers are a waste. I thought since the mufflers were straight through it would be loud so I shopped around on ebay until I found a silencer that would fit. When I listened to the video I could tell the mufflers were quieter without them.
