Originally posted by MidnightriderZ24
View Post
16" look OK if you have 0 offset.
I have run the sports at 3" drop and they work great, but the HD's bottom out. When you shorten the housing, you will still need to put tubing for spacers on the bottom of the damper tube, or they will bounce around inside.
I like the way you are going with the coil set-up, GC overcharges.
