Originally posted by blackbombshell95
View Post
My Long Block Build is Complete!
That could happen if the base circle of the cam wasn't changed during the re-grind, but is highly unlikely with lobe modification.
Thanks. What tool do I use to measure preload? Can you explain it again a little more specific. I kinda understand it and yet i'm kinda confused. TIAOriginally posted by SappySE107 View PostEasy test, put the lifter on the base of the lobe (no lift) and install a pushrod. See how much preload you get (tighten the rocker till the pushrod just spin, no slop, and anything past that is preload).
Do you think it is possible that after they did their measurements that they got the specs of a stock pushrod? Or is their no way in hell? This I want to know. ThanksLast edited by blackbombshell95; 01-15-2008, 06:58 PM.
that is definately different that they came up with the same length pushrods as factory
You're a dick.Originally posted by 1988GTU View PostWhy yes, yes I do! lol
Back on topic, I took one exhaust and intake pushrod off of the new engine and compared it to my stock pushrods and they are they identical to stock.
I just got off the phone with the machine shop and they said that they didn't even have the specs for the stock pushrods. They said they took the geometry from the cam, headgasket, and something else and thats how they came up with those specs. Is that possible even after taking all of those pics to come up with stock specs?
Also, someone tell me how I find the pushrod length out for myself; without having the machine shop remeasure everything again?
through the machine shop. I'm going to compare them to a stock one tomorrow. Maybe it was a misprint because I told him to get the proper measurements.
Yup, they listed the stock length pushrods for your custom pushrods.
Are you sure those pushrods are stock length?Originally posted by SappySE107 View PostOk, going over your receipts, there are a couple things. Those pushrods are stock length. Not a good thing. Also, oil is too thick, use a 5w30 and that comp additive isn't needed. It is only for flat tappet cams, and yours is roller.
