Some parts too look at (Valvetrain)
  • tejohnson
    replied
    Well, it would appear I might have found a workable solution for these specific heads. Since it is a 8mm OD valve stem, and .514 OD valve guide, the Fel-Pro seals with the part number SS70710 should do the trick. The package includes 12 seals ranging from $20-$25 depending on the store. RockAuto.com says they are for the following applications:
    CHRYSLER DAYTONA (1990 - 1993)
    CHRYSLER DYNASTY (1988 - 1990)
    CHRYSLER GRAND VOYAGER 2000
    CHRYSLER GRAND VOYAGER SE 2000
    CHRYSLER LEBARON (1990 - 1993)
    CHRYSLER LEBARON GTC (1991 - 1995)
    CHRYSLER LEBARON LANDAU (1992 - 1994)
    CHRYSLER LEBARON LE (1993 - 1994)
    CHRYSLER LEBARON LX (1991 - 1993)
    CHRYSLER NEW YORKER (1988 - 1989)
    CHRYSLER NEW YORKER LANDAU (1988 - 1989)
    CHRYSLER TC MASERATI (1990 - 1991)
    CHRYSLER VOYAGER 2000
    DODGE CARAVAN (1990 - 2000)
    DODGE CARAVAN C/V (1989 - 1995)
    DODGE CARAVAN ES (1993 - 1995)
    DODGE CARAVAN LE (1987 - 1995)
    DODGE CARAVAN SE (1987 - 1997)
    DODGE DAYTONA (1990 - 1993)
    DODGE DAYTONA ES (1990 - 1993)
    DODGE DAYTONA IROC (1991 - 1993)
    DODGE DYNASTY (1988 - 1993)
    DODGE DYNASTY LE (1988 - 1993)
    DODGE GRAND CARAVAN (1994 - 2000)
    DODGE GRAND CARAVAN ES 1993
    DODGE GRAND CARAVAN LE (1988 - 1992)
    DODGE GRAND CARAVAN SE (1988 - 1997)
    DODGE MINI RAM (1987 - 198
    DODGE RAIDER 1989
    DODGE RAM 50 (1990 - 1991)
    DODGE RAM 50 SE 1991
    DODGE ROYAL MINI RAM 1987
    DODGE SHADOW 1993
    DODGE SHADOW ES (1992 - 1994)
    DODGE SPIRIT (1990 - 1995)
    DODGE SPIRIT ES (1989 - 1993)
    DODGE SPIRIT LE (1990 - 1992)
    DODGE STEALTH (1991 - 1996)
    HYUNDAI SONATA (1990 - 199
    HYUNDAI SONATA GL (1990 - 1997)
    HYUNDAI SONATA GLS (1990 - 1997)
    MITSUBISHI 3000GT (1997 - 1999)
    MITSUBISHI DIAMANTE 1992
    MITSUBISHI DIAMANTE ES (1993 - 1996)
    MITSUBISHI MIGHTY MAX (1990 - 1994)
    MITSUBISHI MIGHTY MAX SWB 1992
    MITSUBISHI MONTERO (1989 - 1993)
    MITSUBISHI MONTERO LS (1989 - 1994)
    MITSUBISHI MONTERO RS (1991 - 1993)
    MITSUBISHI MONTERO SPORT (1989 - 1990)
    MITSUBISHI MONTERO SR (1992 - 1993)
    MITSUBISHI SIGMA (1988 - 1990)
    PLYMOUTH ACCLAIM (1990 - 1995)
    PLYMOUTH ACCLAIM LE (1990 - 1991)
    PLYMOUTH ACCLAIM LX (1989 - 1991)
    PLYMOUTH GRAND VOYAGER (1994 - 2000)
    PLYMOUTH GRAND VOYAGER LE (1988 - 1993)
    PLYMOUTH GRAND VOYAGER SE (1989 - 1997)
    PLYMOUTH SUNDANCE DUSTER (1992 - 1994)
    PLYMOUTH SUNDANCE RS 1992
    PLYMOUTH VOYAGER (1990 - 2000)
    PLYMOUTH VOYAGER LE (1987 - 1995)
    PLYMOUTH VOYAGER LX 1994
    PLYMOUTH VOYAGER SE (1987 - 1997)
    TOYOTA CELICA SUPRA 1986
    TOYOTA CRESSIDA LUXURY (1983 - 198
    TOYOTA SUPRA (1982 - 1985)
    Quite a few. Below are some comparisons with the Intake seal (93734) from the part number SS72685 (Intake being the seals that I had no issues with).
    Old on top of new to eyeball the difference:
    The measurements (while not attempting to expand the rubber):
    Top ID: .275
    Bottom ID: .500
    This seal has the same amount of depth and contact as the old. I went this route simply due to efficiency. I could have bought two packages of the SS72685 and only used the intake seals (93734) which means ~18.00 wasted, unless you could sell the others. The part number 93734 appears to be discontinued, and you will not likely find them individually.
    Any thoughts?
  • Canyonero
    replied
    Interesting indeed. I'll check mine out when I get home.
  • tejohnson
    replied
    The intake valves are 1.76", and the heads have D shaped ports. The part # that is cast in the front of each head (over the plug holes) is: 10218170
    EDIT: Interesting Google results: http://www.pera.org/articles/eb120220.htm
  • Canyonero
    replied
    Ok, so... does it matter if they are 3100 or 3400 heads for the year split? If they are 99 3100 heads, there is a good chance they are different from 99 3400 heads. I know the castings are different -> http://60degreev6.com/forum/showthread.php?t=25040
    I didn't word that right. I'm asking specifically about the valve stem and seal combination. I know the ≤99 and ≥00 3100 heads are different. But ≤99 and ≥00 3400 heads will all work with the 2.2 seals, right? There was no change on the 3400...
    replied
  • tejohnson
    replied
    Sorry, but did you guys read above? The problem is that they are 1999 heads (that is, unless they were switched long ago when I had them ported and polished). [perhaps that was my first question, am I mis-identifing these heads? What is the OD of the valve guides on 2000+ 3400 heads?]
    The OD of the valve guide is .512 for both the intake and exhaust. I did get the 3.1 MPFI seals (Felpro Part Number: SS72685), however, it appears the exhaust seals (70819) are too big. Given the identical sizes of the exhaust and intake guides at .512, the intake seals (93734) should be perfect. I just don't know if that is the same seal that is in the 2.2 cavi seal kit. Will be making a trip to NAPA here in the very near future.
  • Canyonero
    replied
    Can you also use the 2.2 Cavi seals on the '99 and older? Does it matter with the 3400 vs. the 3100. I was under the impression that the '96-'03 3400s were all the same.
    I got the 2.2 seals for mine, which is a '98 3400. Will I have these problems? (I have not assembled them yet)
    replied
    Well it looks like you bought old 3.1 mpfi seals, and I don't know of those heads have the same stem diameter but if the seals are different aparently not. I used Dodge seals on my 05 3500 and didn't have any issues. The two intake exhaust stems are the same diameter as each other 99 or 2000+ they are just different sizes between the years. I'm not sure which set of seals should be used on 99 and older heads.
    iirc 99 and older heads can use the 3.1 MPFI seals, 00+ heads need the 2.2 cavy seals or the Dodge seals i guess...
    replied
  • tejohnson
    replied
    Digging up an aged thread. While starting on my heads to clean them up for selling, I noticed something that irritated me a tad:
    Notice anything odd? The seals that I installed are the felpro "viton" seals (SS72685). Exhaust - 70819 (left)
    Intake - 93734 (right)
    Here is a bit of a closer pic:
    Below are pics of the intake and exhaust guides:
    Valve guide OD - .512
    Valve stem OD - .312
    Measurements for above is for both intake and exhaust. Notice the "step" in the guides. Perhaps these are not 99 heads? I did send them off long ago for P&P, maybe I got a set to 2000+ back?
    Pic of an exhaust seal that cam off the guide, spring still on. No way did the springs move to "lift" the seal off the guide. Only 1 exhaust seal did not come off, and all the intake seals were just fine.
    If they really are 99 heads, given the valve guide OD on both intake and exhaust being the same, why the different seals for intake and exhaust?
  • tejohnson
    replied
    Funny... I just viewed my above posts in Internet Explorer and my posts above look like crap.
    Looks just fine in Mozilla... That's what I get for using HTML in my posts...
  • tejohnson
    replied
    Well... Decided to fix the "hanging" shims. Made a little tool to pull the seals back off without damaging them (I'm so proud):
    Locators after the dremel job:
    On the guide (Before):
    On the guide (After):
    Spring Installed:
  • Syn
    replied
    thanks alot better then the quoted 32
  • tejohnson
    replied
    $19.20 for 12 @ http://www.paceparts.com/index.asp?P...earch=12565118
  • Syn
    replied
    lookin good i just got my ls2 springs yesterday, how much did u pay total for ur shims?
