Anyone ever tried, or know someone that has swapped a 4T60/E/4T65E into a J-body?
J-body 4T65E??!!
J-body 4T65E??!!
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Tags: None
anyone, anyone??Andy
you are getting the same reply i got when i asked the same question about a 440t4 swap !!! LOL01 olds shilluette 3400/4T65-E stock for now
haha. go over to v6z24.com. lot of stuff there on my thread.Andy
OK, the process has begun..finally! i'll keep an update as i get more info.Andy
i will hopfully get a trans for mock up on tuesday ! i am going to try to make it work i hate my 5spd
b.t.w you dont know of any performance parts of the 440t4 do you ?01 olds shilluette 3400/4T65-E stock for now
Are you guys going with the HD variant? You'll need a trans controller. There is a stand alone one now for that trans out.sigpic
i am going with the old school trans 440t4(4t60) but i think that torq455 is going with the new style one with all the electrics01 olds shilluette 3400/4T65-E stock for now
yes, i'm going with the 4T65E. just found out today it's a go-- SWEET ASS!!! i'm ordering the sprocket conversion kit which makes the FDR 3.69, and double checking that the LSD for the HD will fit the standard 65E, will be talking with FAST and PCS about pricing the tranny controller with custom wiring harness, and ordering the tranny.Andy
i am too, but i'm not sure if they did anything different to the diff. not worried about an oil squirter. don't believe any GM FWD tranny has a diff oil squirter. a stock 65E will handle my slightly modded 3.1 even if it was built to the max in n/a trim. i also think you are referring to the W-bodies running 9's. my J-body will never see 11's. pretty sure i'm safe. besides, i won't even be able to touch the engine for at least 2 years.Andy
diff oiling only becomes a real issue if your spinning one tire. with an open diff, if one tire is spinning (say in a burnout) the carrier is spinning so fast that the oil is unable to get into the side/spider gears, the spider seizes up on the pin and it breaks the pin, breaking the case. oil sprayers may help, but the real answer is to put a proper limited slip in and dont do one tire burnouts.
uhhh, yeah...gonna be another month before i can get the parts in. waiting to see about having PCS make FAST's harness for the FAST tranny controller. otherwise, it's all ordered and on the way: 3.69 sprocket conversion kit, LSD, & tranny. tranny will get here thurs or fri. then the brackets/mounts can be fabed at least. slowly but surely.Andy
