3400 vs 3500 top end swap simulation
  • torq455
    If I only had money!!!
    • 1615
    Show me a bone stock 3400 pushing 197 to the ground. No freakin way. Its 175 stock rated from GM at the crank. With tuning I can believe 185 range at best, perhaps 190, chp.
    But we also know that GM tends to under rate their engines.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    • Fiero11
      • Apr 2005
      • 64
      Auto makers use an SAE test for computing horsepower. It gives hp numbers about 4% lower than dyno numbers.
        • 13522
        Well, that is true. Phil had 5 degrees KR minumum on his stock dyno runs. That was a mustang dyno as well which usually gives lower numbers than the hydraulic based machines. They also require correction factors for the fluid temp vs electric dynos.
        Here are the 56mm vs 62mm vs 65mm TB on a stock 3400. Wave action model.
