Originally posted by SappySE107
View Post
3400 vs 3500 top end swap simulation
But we also know that GM tends to under rate their engines.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Well, that is true. Phil had 5 degrees KR minumum on his stock dyno runs. That was a mustang dyno as well which usually gives lower numbers than the hydraulic based machines. They also require correction factors for the fluid temp vs electric dynos.
Here are the 56mm vs 62mm vs 65mm TB on a stock 3400. Wave action model.Attached FilesBen
