Coming Soon: Higher Ratio Rockers
  • gectek
    Banned
    • Aug 2006
    • 1472
    #31
    Do it like a redneck... use a dremel with a cutoff wheel and grind the slots in the heads.. just don't let any metal get down in the oil
    (only kidding)
    thats what you use duct tape for...geez. and Isaac why didnt you switch to the newer alum heads??? like the 3100s at least? actually on the LS engines, they dont use guideplates when you put the scorpion rockers on because
    they have pedestals that go on the roller trunion and aparently didnt need them and didnt move...so idk if you would need guide plates, may keep them for piece of mind though...
    • Nightingale
      • Apr 2005
      • 259
      #32
      I am definitely down for aftermarket valves on the 3900! I've been looking into it, but if i can just order a set without having to fill out a custom order sheet then praise to the high heavens!!!!!!!!
      98 camaro swapping in lz9 th400 setup
      LZ9 specs: (Subject to Change work in progress)
      4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
        • 13525
        #33
        3900 valves will be done but not right away.
        • Nightingale
          • Apr 2005
          • 259
          #34
          Understood at the rate I am going I might have the engine mocked up by end of this year lol. So if the time scale is say 3-6 months then were good .
            #35
            gectek: I do have 3100 heads, cause it's a 3100 :P hehe. Cause I'm not gonna drop several hundred on heads and gaskets on this old ass 215,000 mile motor. When I could spend the same for a low mileage 3400. But I don't have a the means nor a reason to swap engines (still runs damn good) at this point so that won't be happening either.
            • MY91GT(Z)
              • Sep 2006
              • 387
              #36
              me would go for 1.7 or da 1.75 pendn what would be good for my set up on stoc cam and .020 shaved heads
              • gectek
                Banned
                • Aug 2006
                • 1472
                #37
                but i thought the 3100 had the slots in them...or am i on something?
                on a side note...you could just center punch and drill a hole on each side of the bolt hole, then dont completely shave the alignment tabs off and still have some sense of rocker/pushrod alignment...i helicoiled the rocker hole on my car with the head still on the engine...and of course it was the back one, so that sucked. Then i used 1 tips to clean out the hole both after i drilled and after i tapped...that melling break in lube is some very sticky crap and worked great to clean all the shavings out.
                  • 9190
                  #38
                  Early 3100s (93-95) didn't have the slot. There are SOME 95s with the slots, but most do not have them.
                    #39
                    Yeah I'd love to have easy bolt on rockers for more lift/duration but it won't happen. I just need to take the oil plug out so the motor goes and I have a reason to put something better in, cause it sure ain't going to go on it's own accord! LOL
                    • gectek
                      Banned
                      • Aug 2006
                      • 1472
                      #40
                      or you could just score some later model heads...i can get some 3100 heads off a wrecked malibu here, its an 01 model i think...that would help out wouldnt it??? i can price em for yah also
                        200k+ on a lower end, a head swap isnt worth it... I doubt he is still getting 160-180 compression at all cylinders.
                          #42
                          See my post above further up... Price of heads, having them checked/decked, and headgaskets would add up fast. And to put a fresh top end on a 215,000 mile bottom end? Eh, I'd rather spend that money towards a low mileage complete 3400/3500 ya know. Thanks for the offer though. This motor isn't getting opened up ever again, especially since it has metal intake gaskets now, no need to take the intakes off again. Oh and new timing chain and gasket, so yeah, it's run it till it dies, or I get a 2nd car, place to work on it, and an engine stand and hoist. lol
                          EDIT ^^ 3400 beat me to it. I don't know, I need to do a compression check. My friend with a 250,000 mile 93 intrepid V6 had great compression. So mine could be good too. Mine is a beast, even in this hot ass weather. I don't know what it is. I guess the BLMs are finally fully adjusted for the intake mods... The throttle is super touchy on the low end even with a 52mm TB on there right now. It just breaks the 225mm tires free super easy. I need to get rid of the stock exhaust and stock original catalytic converter! LOL
                          Now I'm curious what my compression is... LOL
                          Hey Ben, when are we gonna see what these rockers might look like? Will they work on stock springs?
                          • gectek
                            Banned
                            • Aug 2006
                            • 1472
                            #43
                            you will get to see a sneak peak of them soon hopefully, ill get them to ben as soon as they come in for his testing and drooling phase lol
                            • gectek
                              Banned
                              • Aug 2006
                              • 1472
                              #44
                              So here is a rough update from scorp...looks like we will have to wait until after PRI show to get the prototype rockers from them...they have too many projects just like we do...and if i can get more interest in them...they may get done sooner, but of course i need a price...ill see what i can find out tomorrow....
                              • rsisbetter
                                • Mar 2006
                                • 151
                                #45
                                awesome!
