Coming Soon: Higher Ratio Rockers
    I would probably go for 1.65 set or 1.7 if Ben thinks that will compliment my engine more... What do you say Ben?
    • gectek
      I Hate Nose Hair
      • Aug 2006
      • 1472
      #47
      itll all be in the measurement of how much lift you can use and what the max lift of your head is until you reach the land of diminishing returns you know
        Damn, 1.7's would put my cam to a 549/603 lift cam... HOLY HELL... 581/639 on 1.8's
        the 1.65 may be a good idea, that gives some a minor jump if they dont want to go so high, 533/586 on mine for example.
        My lifts would be as noted above... And according to Ben I could support these lifts with my comp springs. My heads are unmodified so if they support 549/603 lift then I should be just fine.
        • FallenZ24
          • Nov 2005
          • 178
          #49
          Im just curious what the lift would be with the 1.7 rockers and stock cam? I have LS6 springs and LS1 spring seats. Would those springs handle the added lift of the high ratio rockers?
          -Joseph
            • 13520
            #50
            .457 lift, which is fine with your setup. 1.8 is .484 lift, which is also fine with LS6 springs.
            • FallenZ24
              • Nov 2005
              • 178
              #51
              Thanks for the info Ben. That .484 lift sounds quite nice. I'll have to keep my eye on this thread for updates. This is deffinately more cost effective and easier than a cam swap.
              -Joseph
                #52
                What about stock springs?
                  • 13520
                  #53
                  Id rather not.
                    #54
                    Stock springs that bad eh? Oh well for those that already have upgraded springs even the LS6 sounds like an easy bolt on upgrade.
                    • kwhauck
                      Olds Sleeper
                      • Aug 2006
                      • 379
                      #55
                      Ben - So when are these valves expected to be available? What is the diameter on both of them compated to stock? I am looking to order new pistons, but they need valve diameters, but i may wait for these to come out first
                      Geteck - don't you think the 1.7s are too much? even the 1.7s will put me over 600 lift......
                        • 13520
                        #56
                        stock size. I don't know when the valves will be ready right now.
                        What cam and what is your setup. I can tell you if .600 lift will do you any good.
                        • gpse3400
                          • 1460
                          #57
                          Originally posted by sappyse107 View Post
                          i was going to wait, but i can't. This is too good to sit on scoggin dickey is backing scorpion to have higher ratio aluminum rockers for the 3100 3400 and 3500 engines. These will be pedestal mounted as a drop in and go deal. 1.7 and 1.8 at least, with possibly 1.65 and 1.75. I don't know if we need those .05s in there but its an option. Scorpion has given it the greenlight, which is why i am posting.
                          Pricing soon. We are looking to offer them in sets of 6, so that you can mix and match intake/exhaust. I feel this is vital to get the best setup for every application.
                          May as well share a few more bits of info since this is a pretty big annoucement for the 60v6 community. Manley is making their super duty valves (race master exhaust and race flo intake) for the 3400 3500 and 3900 motors. I am designing the valves to optimize flow with extensive testing being done on the flowbench to get this right. For those running boost, or just wanting the best, these will be by far the best on the market. You can thank scoggin dickey for this as well. I am working with john at sd on anything 60v6 they will let me get my hands on
                          this also means im extremely busy. The site/store will be updated eventually, once this r&d session has produced something we can all be proud of
                          to notch, top notch!!!!
                          Lorenzo
                          • kwhauck
                            Olds Sleeper
                            • Aug 2006
                            • 379
                            #58
                            Comp Cams special order roller
                            230/242 @ .050 duration
                            280/294 @ .006 duration
                            .577/.577 lift. 115 LSA
                            Setup
                            Bottom End:
                            CP 8.8:1 Pistons
                            Scat 800hp Forged SBC rods
                            3400 Cryo-hardened crank with Double Roller
                            Upgraded Bearings
                            ARP Main Studs
                            ARP Rod Bolts
                            Dry Sump oiling system (not done yet but peterson fluid systems will most likelly be doing the work)
                            The Rest:
                            Ported 3400 heads with 26986 springs (or whatever you think is best)
                            Ported 3400 LIM
                            Ported 3500 UIM
                            Custom Headers
                            1600AX Whipple
                            Spearco W2A Intercooler
                            Built 282 Getrag
                            And obviously all the accomodating stuff (walbro pump, injectors, hp tuners, stiff suspension,etc)
                            The setup will be running 16-22psi hopefully making 450+WHP and enough to launch me into the 11s.....
                            • alerored04
                              • Sep 2006
                              • 126
                              #59
                              Anyone have a guess of gains to be seen with 1.7's on a 1393 cam with comp springs? What would that put me at for total lift? Could larger ratio's be used without chancing damage? Stock bottom end, ported top end. Thanks guys.
                              Lots of mods cost lots of $$
                              http://www.cardomain.com/ride/2598719/1
                                • 13520
                                #60
                                1.7 is a waste of time according to dynomation on your setup. It likes a belt ratio of 2:1 roughly with that cam.
                                Setup
                                Bottom End:
                                CP 8.8:1 Pistons
                                Upgraded Bearings
                                ARP Main Studs
                                ARP Rod Bolts
                                The Rest:
                                Ported 3400 LIM
                                Ported 3500 UIM
                                Custom Headers
                                1600AX Whipple
                                Built 282 Getrag
