Coming Soon: Higher Ratio Rockers
    same here, pending results on my cam, and best ratios for it. N/A and nitrous.
    • Nick-G
      11's or Bust...
      • Feb 2008
      • 224
      #77
      Im for sure buying a set of these too.
      BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
      • MY91GT(Z)
        • Sep 2006
        • 387
        #78
        i def will be buyin a set of these when they come out
        • FallenZ24
          • Nov 2005
          • 178
          #79
          I deffinately will get a set. I just was hoping to save a little money if possible. The stock cam with .484 lift would be quite nice for a turbo setup. I guess I need to start saving $20 a week. Haha!
          Also, will these rockers require custom pushrods?
          -Joseph
          • gectek
            Banned
            • Aug 2006
            • 1472
            #80
            well i will try to keep prices down as much as possible, but i dont think that they higher ratios will cost much more than the lower ones...ie 1.8 price wouldnt be far off from the 1.6 price, but there will be some, they take more engineering and material to a point...
              • 13525
              #81
              Pushrod length depends on the cam. These rockers shoudln't require anything but installation.
              • rsisbetter
                • Mar 2006
                • 151
                #82
                nice! bolt-in ftw! i can say, count on me...once my crane golds fail that is! judging by the crane gold's past reputation, it shouldnt take long. haha.
                unless somone wants to buy my crane gold's, then you can put me down for a set!
                • Azrael
                  Accelerating uphill in OD
                  • Apr 2005
                  • 763
                  #83
                  I'm looking forward to these too. I don't have the mechanical confidence to change a cam but higher ratio rockers are the next best thing.
                  1995 Grand Am SE
                    #84
                    But these will require stiffer than stock springs though.
                    • gectek
                      Banned
                      • Aug 2006
                      • 1472
                      #85
                      i really dont see any prob with that??? isnt that what we all do anyway?
                        • 13525
                        #86
                        I would recommend stiffer springs with better coil bind properties for anything that isn't stock. Stock springs are a bit pathetic.
                        • zofo61
                          Banned
                          • Oct 2005
                          • 436
                          #87
                          How bout 3500 heads LS6 springs / 3400 bottom.....boosted with the RSM kit? What would you recommend with that combo,........ Ben?
                            #88
                            Nothing wrong with better springs, but I was just referring to the post above that talked about a cam being daunting possibly. I think sliding in a cam would be easier than messing with springs under tension, lol. Can you change springs without pulling the motor? Or is there not enough room?
                            • geldartb
                              The Situation
                              • May 2004
                              • 1994
                              #89
                              you can change springs without pulling the heads.
                              use something like this
                              if you use the C clamp style then you have to pull the head.
                              99 Grand Am GT
                              1357 cam 227 233 .050 dur
                              515 515 lift 112 lsa
                                • 13525
                                #90
                                Yeah, and if you get a regular rocker stud, you can use the fulcrum style to compress the springs. I don't care for the style in the pic you posted but they do work.
