Custom Intake Manifold
  • onefastV6
    • Sep 2005
    • 880
    #271
    Once you get the design down, contact these guys http://www.reliablecastings.com/ and see what it would cost to make it a reality. I wonder if Marc has ever used them as they are based out of Cincinatti, OH.
    As the 3400/3500's are dead by GM standards, I wonder if they would release any design information that would help with this project?
    2000 Grand Am GT
    2011 Chevy Impala
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      #272
      The casting is cheap. The tooling is not.
      • TechRod
        Destruction Worker
        • Feb 2009
        • 162
        #273
        Forgive the noob question but is this something that could be made via DIY sand casting and a backyard foundry or would it just be too complex a part?
        "It's your car. Do with it what you wish, but as you enter this unknown world you will need to invent the wheel all over again. For the adventurous and those that are backyard mechanics who have nothing but time you might like this. Most have plenty of frustrating moments and the process usually takes significantly longer then what anyone could imagine. The end result of this conversion is completely up to you." - Jon McCullough of BMCautos.com
          we actually have a fairly new member on W-body who does sand casting for stuff like strut bar mounts and similar things... i may need to point him here to see what he thinks.
          • unchained01
            • Jan 2011
            • 388
            #275
            yeah that guy (jerryirgg) is on here and is on w-body as rocketman he makes some very good castings
            • JerryRigg
              "Rocketman"
              • Nov 2010
              • 57
              #276
              Yup that'd be me, Rocketman was already taken here so I'm JerryRigg
              If you go back a page I posted a manifold I made for the Mazda B6 4 cylinder: http://60degreev6.com/forum/showthre...l=1#post439597
              I'm capable of making both the tooling & the casting, at least in moderate volume. I work out of my backyard, but I have a lot of equipment & can work on a larger scale than your average backyard caster. Would need to find someone or a shop to do the machining though, I don't have the tools for that.
              At this point, I'm waiting to get to the junkyard so I can pull a LIM & UIM. I need one on hand for doing my own CAD work as well as planning out the tooling. Cash is tight for me at the moment though. If its a supercharger intake we all want, I'll need to locate one too again for layout & planning. A modular design is a good possibility too.
              RIP - 94 GP SE
              DD - 95 GP SE
              Fun - 91 Mercury Capri XR2 Turbo AWD Conversion
              http://www.werbatfik.com
              • JSGTU88
                • Jan 2011
                • 1
                #277
ID:	376691Click image for larger version
ID:	376692Click image for larger version
ID:	376693Click image for larger version
                I figure this is as good a place as any to throw out my plan/question. I've been looking for someone to make my design a reality somehow. Yes, my design is a rip-off of the 90 beretta pace car design, but who cares, I just want to make the thing. Can anybody help make this happen?
                Thanks!
                Jon
                  well hello, TPI, haven't seen you since the 85 IROC disappeared.
                  it looks like it's going to be a bit taller than a stock UIM, but enough to cause concern about hood interference?
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    #279
                    I'm thinking the Lower should be designed similar to the old TDC lower, or at least use the same flange between the upper and lower so you don't need custom gaskets.
                    • unchained01
                      • Jan 2011
                      • 388
                      #280
                      so has anyone made any progress on this ? any ideas ? as far as machine work , cncguy may be the one to talk too about that.
                        • 9191
                        #281
                        Wife and kids are gone for a couple days, so I may have some time to work on my CAD design some more. I have a few other things I need to get done as well, but I should be able to make a little more progress on this.
                        • unchained01
                          • Jan 2011
                          • 388
                          #282
                          Any other ideas ? Or progress ?
                            • 9191
                            #283
                            Unfortunately, no. Other stuff came up, so I never got a chance to even look at it...
                            Sent from my DROID2 GLOBAL using Tapatalk
                            • 95cutlassproject
                              • Jul 2010
                              • 61
                              #284
                              this idea just came to me snice this is suppose to replace the upper and low manifold maybe it could be clearanced so we could use larger ratio SBC rockers if someone asked that yet.
                              Researching phase for project ( screamer engine reseach, in the coming years)
                              • JerryRigg
                                "Rocketman"
                                • Nov 2010
                                • 57
                                #285
                                Anyone have any progress?
                                I obtained an Eaton M62 and had it laid on top of my 3100, I believe it'll sit down there nicely, might have to play with fuel injector fitment a little bit.
                                RIP - 94 GP SE
                                DD - 95 GP SE
