Originally posted by onefastV6
View Post
However, the TPV can't be regulated on pre-02, and since the wiring is the same you shouldn't have a issue.
On another note, I've had time to play around and have found a few tricks to force it
to shift into OD (it'll go into 4th but it won't go into OD.) Driving in 3rd for a while then changing to OD seems to open that gear up. So not sure if the issue is a linkage issue or not. 1st/2nd do not work on the current trans, but 3rd does. Looking at the 05 GAGT bin in HP tuner also shows those two grayed out so I don't think there is a issue there. Anyway just some random observations. Overall, it's been behaving most the winter as long as I let it cool off for at least 2hrs between driving. Weird but overall I can't complain.
Been working a lot so haven't had a lot of time to really dink with it or even think about what to do next.
I also have to track the crank code down. I may just try re-relearning in case that failed, but I'm guessing it's a wiring issue somewhere. Going to replace the two sensors and have the wiring redone for the external sensor. Considering the wiring on the TPV valve went bad from the work at the last shop, it wouldn't surprise me if it's something simple.
Hope that helps!
