The newly designed efi cleaner-fuel rail is done!
Okay Gentlemen...It is DONE!
For the Latest Video and 33 New Images...Go Here Please...
I finally finished and completed the build of the Newly Designed EFI Cleaning Fuel Rail this evening! I'm glad I opted to go with the Schrader Valve modification rather than use the Brass Barbed/S/S Clamp method of introducing the EFI Cleaner under pressure into the rail. It took a bit of doing...but I finally managed to braze the steel Schrader segment on top of an extra Barbed fitting I had and controlled how much supporting "Ramp" I had at the base that would give it strength and not fill up the threaded top of the unit or invade the interior and well up inside the inner threads and act as a barrier against being able to screw the removed pressure valve back inside after it was cool enough to work with, clean up and re-install the valve.
I am also glad for the admonition by Robertisaar... (Robert) That "Simple... is Best!" as the Final Design more than meets that criteria, albeit with no small amount of R&D in eventually getting to that point in its construction.
I took a short trip up to Dimmit Chevrolet with my New "Brass Piccolo" in hand and got the weirdest looks from the Counterman...until I explained what I was up to. He smiled afterward and looked up some EFI Clip and "BLUE" O-Ring Kits for a 3800 Series GM car and ...Well Whadyaknow? They worked PERFECTLY in holding the EFIs on the New Rail and allowed me to dispense with two hands-full of S/S Clamps and all those mini-pieces of Acrylic Hose that I was using before.
Tomorrow morning... I'll finish mounting this finished item on "The FrankInjector" after giving it a very thorough last cleaning ...inside and out ...and then install some EFIs that have already been "EUMAXED" in the Ultrasound and flush them clean via this rail. Afterward ...I'll be able to do a Flow Balance Test on a Full Set of Six (6) Injectors ...and see how they behave when NOT mounted on the stock GM Fuel Rail. Of course... I'll memorialize the results on video and we'll all see whether this extra effort was worth doing...or not. I would also like to change the "Question" status of this thread to "Answered" since the original problem was trying to find a way to drive all six pintles inside the EFIs during the Ultrasonic Cleaning as well as during the EFI Pressure Cleaning and Flow Balance Tests. That answer has come in the form of having to use one (1) OTC EFI Tester per (3) EFIs and so, in the absence of somebody helping with the circuitry to drive all six in some other controllable electronic manner...the Dual OTCs will have to satisfy. Well... I'm fairly tired now after burning through this part of the build today ...so please take a moment and visit my photo bucket listing below for the Video showing the layout and EFI /Clip installation on the finished rail and the thirty-three (33) new still images of the building of this Final EFI Cleaner-Fuel Rail.
