Originally posted by geoffinbc
View Post
It has little or no affection to hp what the WOT timing is.
It maybe so that when other things are not perfect (in this case runner lenghts, plenum etc...),
it affects so.
You are right, I am not going to hack the intake apart, I just modify the upper part of it.
I mean ,shorten the runners and maybe make the plenum a bit bigger.
The runner lenghts with different carbs:
4 bbl Holley 6-7"
3 bbl PMO 6"
2 x 2 bbl Weber 13"
with those applications above , the power was about 150-166 kW
And with 3 bbl PMO carb with the 3" extension ( together 9"), the power was 186 kW (254 hp back wheels), the best so far.
With this combination, the exhaust temperatures were over 100 degrees celsius different from bank to bank (over 212 F).
It means the other bank did run lean and the other rich.
So, 9 inch may be the best runner lenght .
And the exhaust temperatures are the same with 2 x Weber application .
