Back to the custom push rods. Im going to purchase a push rod mesurement tool but have no idea what size of length im looking at. There a few different adjustable tools ranging in lengths. If I was to get 6.125-7.50 inch tool would that work or would i want a shorter one? This is for the 3.1L Gen1 block and a Delta cam 260 grind cam and lifter set with the 3400 gen 3 heads atop. Im not sure what the preload on the lifters should be as of yet but regardless i just need to know a range of what it will be so i can pick up the tool. Thanks again everyone!!
3.1L/3400 hybrid swap.
1/4 mile best 11.59@119mph
1/8 mile best 7.47@94.9Mph
After Christmas I plan to get my pistons, also I plan to take the block to the shop to get bored/honed...exc once i have those pistons in hand.
Are these pistons correct? There for all passenger cars 3100's. Im planning on boring the cylinders out to .030 over. http://www.summitracing.com/parts/sl...make/chevrolet
Also I currently have delta260 cam but opted to get a 272 grind from them. The lift will be upwards of .500 and a tad more on the other side. Im looking to get a set of yellow ls6 springs to match the cam and take the lift.Last edited by fasteddi; 12-11-2013, 05:34 PM.BorgWarner S366 3.1/3100 Turbo Thirdgen
Look for my engine build thread on TGO... The pushrod sizes are in there.
If you insist on doing it yourself, however, get the Comp checker listed in the WOT-Tech pages (you will need to go there anyways for the pushrods).
Keep in mind the STOCK 1996+ rocker arms on the 3x00 series are 1.6:1 ratio and not 1.5 like on your current heads (if the rockers are roller fulcrum they're 1.6... pre-96 used the usual 1.5:1 stamped rockers).
Might call Summit and make sure those pistons have the 28cc dish otherwise your compression will give you fits with the turbo.
:edit: Would you be willing to part with the old Delta cam when you don't need it any more?Last edited by Maverick H1L; 12-11-2013, 08:08 PM.
Ok mav. Ill check out your page.
Yea I would part with the delta cam and lifters to match. I have 2 stock cams still in case i ever need a core.BorgWarner S366 3.1/3100 Turbo Thirdgen
Actually, Pre-96 gen 3's are also 1.6, just ball fulcrum like the gen 2's and Gen 1's had.Originally posted by Maverick H1L View Post(if the rockers are roller fulcrum they're 1.6... pre-96 used the usual 1.5:1 stamped rockers).
It's a popular upgrade for the gen 2 guys.
Update
I rewired the fuel rail to fit my injector connectors, cleaned up the intakes and gave them some coats of hi temp paint as those were horribly dirty.
I've began to start buying parts.
I got a 3.4L new 7x trigger sensor on the way, a new rfl blow off valve. The old one was past its days.. Also a delta 272 cam/lifters and a new timing chain set. Im still aiming to take the block to the mach. shop after christmas to get it bored over .030. The shops getting the pistons and such as they are selling them to me cheeper then I can buy them from anywhere on the net. I plan on just going to a JY for the 3.4L camaro alt bracket once I get a nice non snowing day...BorgWarner S366 3.1/3100 Turbo Thirdgen
DIS questions.
The 2 crank sensor wires will connect into the DIS module. Then there is a reference output, a ground output, a system ground, a bypass output, and est outputs.
On my old wiring I would connect the est wire with the new one, i would connect the reference with the new one, i would connect the bypass with the new one, but then there is a REF Low on the old dizzy system? What would I do with that? Do I even need that input to the ecm anymore because I don't see what I would use it for.
I assume that the system ground and the ground from the Dis module is suppose to be separate? System ground is to the ecm ground and the other ground is to the frame?
Im running code 59 so hopefully i can set up the bin correctly but first i need to start some wiring as the engine is coming out tomorrow. Id like to start to straighten up my harness and any wiring that needs redone.. Currently I have piles of wiring diagrams in front of me so Im trying my best just to figure it out but if anyone can help i really appreciate it!BorgWarner S366 3.1/3100 Turbo Thirdgen
Simply:
Pink to pink
Black/White to Black/White or just to the frame/engine
Black/Red to Red/Black (IDK why they swapped the wire colors but they did and the function is the same)
Purple/White to Purple/White
White to White
Tan/Black to Tan/Black (you can leave the EST bypass connector if you want)
Crank Sensor:
Yellow to Yellow
Purple to Purple
There MAY be a ground but it will NOT be at the sensor and it's a shielding wire)
Low reference always means ground afaik... Sometimes grounds are supposed to go through the ECM however. When I wire in the DIS I always end up with an engine ground on the two wire sensor (other wire is IGN+ power).'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
Ok. Thanks guy for the info. That helps me alot!
I did get the engine pulled today and started dissembling the block for the shop. I just need to remove the cam and crank. Everything else is out, cleaned, and labled. Once thats done I can start cleaning up the engine bay area and doing some wiring connections this weekend after christmas.BorgWarner S366 3.1/3100 Turbo Thirdgen
I forgot there's 2 white wires...
The wire at the DIS module's large connector, terminal C, is for the TACH. The other one is the EST wire. There is no wire, generally, in D, IIRC. Also, keep in mind that some have had issues with the tach when swapping to DIS.
Any idea how well they work with a autoguage tach? The stock one isnt accurate at all but the AG tach is what I use.BorgWarner S366 3.1/3100 Turbo Thirdgen
